[Closed] Uneven vertical surface on long prints
mabouche.l
(@mabouche-l)
Hi all,
I'm having an issue (as far as I remember) with my MK2, it's doing great print (I think) but for some reason when the print is high, it get this uneven vertical finish.
Here are some picture of the problem, it should be easier to understand.
I've printed both models separately, and as you can see it appears at the same height, I've seen this on other prints too.
Do you guys have any clue what could cause this ?
Thank you in advance for the help 🙂
PS: Sorry for my approximate explanation, I don't know exactly how to define or name this problem.
Napsal : 15/05/2018 10:07 am
Knickohr
(@knickohr)
Member Moderator
Re: Uneven vertical surface on long prints
This is the starting position of the layer.
Maybe you can play with the settings for better result :
Slic3r
Print Settings
Layers and perimeters
Advanced
Seam position
Thomas
Napsal : 15/05/2018 11:43 am
nenad.b
(@nenad-b)
It could be model related. To elimnate the possibiliy, try to repair using Netfabb service or try with other model.
Napsal : 01/06/2018 4:04 pm
nenad.b
(@nenad-b)
It is retraction related. Recently I assambled new printer and had similar problem. Extruder gear was not fixed correctly and there was no retraction. When extruder retracts, the motor goes backwards.
Napsal : 06/06/2018 10:36 am
