Strange pattern!
Deb
 Deb
(@deb)
Strange pattern!
Does any one know what is causing this strange pattern that is going on here. Nothing shows on the screen, and when I print it, it look like this. I have tried slowing the print...doing detailed vs. optimal. I don't know what else to try!
Veröffentlicht : 31/08/2018 1:07 am
Re: Strange pattern!
What layer height are you printing at? The layers that look like a topographical map are the inevitable result of the FDM printing process. You'll always get some stair-step effect between layers, but using finer layer heights can help to a point.
If you'd care to share a link to the STL we can take a look at it, but largely flat surfaces like that with small height increases will show some stair-step effect.
Veröffentlicht : 31/08/2018 8:23 am
Neal
 Neal
(@neal-3)
Yep...what he said.
Neal
Veröffentlicht : 31/08/2018 5:17 pm
Deb
 Deb
(@deb)
Thank you both...I'll try changes my height and see if that helps 🙂
Veröffentlicht : 01/09/2018 12:27 am
