prints do not stick to support Slic3r
ozyreusz
(@ozyreusz)
Hello
My prints stick and print well when they are printed from the bed but when i need to print something on a support structure it fails
I use pla .15 layer hight
Examples
The plastic just falls of the support and in some cases Iit resumes thaks to bridging but the quality is very bad
My support settings
Veröffentlicht : 27/05/2018 8:51 pm
lee.g
(@lee-g)
Re: prints do not stick to support Slic3r
Try changing the contact Z from 0.15 to 0.07
Veröffentlicht : 14/07/2018 2:22 pm
richard.l
(@richard-l)
Mitglied Moderator
I have had good results with Contact Z at 0.12. At 0.07 the supports are going to weld themselves to the print and be much, much harder to remove.
Veröffentlicht : 16/07/2018 3:31 pm
lee.g
(@lee-g)
Have you tried it.
Mine don't weld at 0.07 and the face that is supported is of much better quality.
Veröffentlicht : 04/08/2018 1:58 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Personally I print with a support interface Z-gap of 0.15mm. Anything less is almost impossible to remove.
Peter
Veröffentlicht : 04/08/2018 8:08 pm
richard.l
(@richard-l)
Mitglied Moderator
Have you tried it.
Since the original post I have. If I go any lower than .10 the supports get welded to the print and are not able to be removed. For me, personally, 0.12 is my sweet spot.
Veröffentlicht : 06/08/2018 1:49 am
lee.g
(@lee-g)
Thank you for trying.
I printed a model last night that had radiuses and flat faces that needed supporting. It worked well for me at 0.07 and I had a good quality support face. As good as a supported face can be.
I think it is one of those situations where other settings can also influence what results you get.
Veröffentlicht : 09/08/2018 2:53 pm
