Printing 205mm tall model
Hi.
I know the spec for the pruza Z axis is 200mm. However when moving axis manually in the menu I can move the Z axis to 205mm and still there are slightly less than 1mm left of clearance before running out of mechanical travel.
Question is: Will it be possible to print a 204mm tall object?
Re: Printing 205mm tall model
Wiith a little bit of modding, you can print up to the upper end of the frame (26 cm possible https://shop.prusa3d.com/forum/improvements-f14/30-more-build-volume-26-cm-build-height-working-t6088.html#p42902 )
Just looked in the firmware:
You should be able to print you model without changing anything.
Thank you for your input.
Should be possible is great, but if someone had actually tried or know for sure it would be even greater 😉
I am about to start a 50 hour print, would be a shame if it stops 4mm before it is finished.
Maybe I will make a small and tall fast-printing part just to check first.
