Nozzle Wipe
adrian.s2
(@adrian-s2)
Nozzle Wipe
How do you specify where you want the nozzle wipe to occur at the beginning of a print?
Over the years, I have started to damage the PEi sheet around the top edge from removing the bits of excess plastic.
I was hoping to shift the nozzle wipe to a fresh area.
Is there some GCode in Slicer, or is it baked into the firmware?
Any help much appreciated.
Thanks.
Postato : 06/10/2018 4:09 pm
kevin.r5
(@kevin-r5)
Re: Nozzle Wipe
The intro line (or nozzle wipe as you've called it) is part of the 'Start G-code' in your slicer setup.
G1 Y-3.0 F1000.0 ; go outside print area
G92 E0.0
G92 E0.0
-Kevin
Postato : 06/10/2018 4:42 pm
adrian.s2
(@adrian-s2)
Re: Nozzle Wipe
Thanks.
That's where I thought it would be but this is all that is in my 'Start G-Code' in slicer.
M115 U3.1.0 ; tell printer latest fw version
M83 ; extruder relative mode
M204 S[machine_max_acceleration_extruding] T[machine_max_acceleration_retracting] ; MK2 firmware only supports the old M204 format
M104 S[first_layer_temperature] ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] ; wait for extruder temp
G80 ; mesh bed leveling
Postato : 06/10/2018 4:51 pm
kevin.r5
(@kevin-r5)
Re: Nozzle Wipe
The lines you posted are what I see in Slic3r when I bring up the settings. The lines I posted are present, but not visible until I scroll the text box containing the 'Start G-Code'.
-Kevin
Postato : 06/10/2018 7:02 pm
Re: Nozzle Wipe
Hi Guys,
I put a piece of 10mm capton tape across the prime line area on my PEI sticker, and it both covers the area where a piece of pei ripped out, and makes the prime line easier to remove after a print!
Postato : 07/10/2018 2:03 am
adrian.s2
(@adrian-s2)
Re: Nozzle Wipe
Thanks guys.
Found the G-Code now. Amazing what you can do with the scroll bar!! 😳
The tape idea is also great. I may try that too.
Thanks all.
Postato : 07/10/2018 9:27 am
Re: Nozzle Wipe
Joan
Postato : 07/10/2018 9:56 am
