Large object print
Hello Guys,
does anyone have experience with printing large object? I need to print a part that conforms to the maximum dimensions of the printing area.
The problem is probably with the adjustment of the supports. The supports create an outline around the object. TEXT: a path outside the print area was detected...
Can you help me pls? Thank you.
Respondido : 23/12/2020 3:45 pm
RE: Large object print
I've done things like this by turning off the skirt and using support blockers to remove the supports that are outside the tool path.
I've found that there is virtually no leeway with the stated dimensions, and with Cura (not relevant to this particular situation) it's even a couple of mm less.
Respondido : 23/12/2020 5:27 pm
1 les gusta
