Y axis gets stuck sometimes
asawal555
(@asawal555)
I have been using prusa i3 mk2s for almost a year. Recently i started getting layer shifts on y axis.
Layer shift usually occurs around 4 - 5th layer. I have tried reducing the print speed but no difference.
Belt tensions are okay.
Nothing restricting bed movement
When i remove the belt, bed moves fine without any hindrance.
Here are video links of bed movement:
1) Bed get stuck while moving with hand
https://drive.google.com/open?id%3D1ahja315oWZOfdkfYQ0achwNtm0C_JDay&source=gmail&ust=1576081049089000&usg=AFQjCNE_bBw8T0ID5zwYSP_UKgkjzLt1A Q"> https://drive.google.com/open?id=1ahja315oWZOfdkfYQ0achwNtm0C_JDay
2) Printer Auto-Home correctly
https://drive.google.com/open?id%3D1pQrvFHlKVWZi-DL-2Fx6unM7ncx_jerb&source=gmail&ust=1576081049090000&usg=AFQjCNE-VcLKa_LQfllmIVTyHy8xTYznM g"> https://drive.google.com/open?id=1pQrvFHlKVWZi-DL-2Fx6unM7ncx_jerb
3) Bed moves fine while operating from the control knob
https://drive.google.com/open?id%3D1IgqDizaeguFmD-AMEj443VEFKuOeEWJT&source=gmail&ust=1576081049090000&usg=AFQjCNGof31_dUMeZzUPNKauD-Ol1tiFO w"> https://drive.google.com/open?id=1IgqDizaeguFmD-AMEj443VEFKuOeEWJT
4) Belt tension
https://drive.google.com/open?id%3D12qTlgalo04GruQLzI5aXOrYtoLt1L4HK&source=gmail&ust=1576081049090000&usg=AFQjCNGiEmDvqr749plmvU1CGVucKQP3- Q"> https://drive.google.com/open?id=12qTlgalo04GruQLzI5aXOrYtoLt1L4HK
5) Bed moves smoothly when not connected to motor
https://drive.google.com/open?id%3D1DajG1q-I1q7ZVeXoiQ7fwaERkWcISxyn&source=gmail&ust=1576081049090000&usg=AFQjCNHDOecqhcw4FUQGqeO2KltXQQyG- w"> https://drive.google.com/open?id=1DajG1q-I1q7ZVeXoiQ7fwaERkWcISxyn
Postato : 10/12/2019 10:18 pm
RE: Y axis gets stuck sometimes
try lubricating the smooth rods!
Postato : 10/12/2019 10:58 pm
jean-marc.v
(@jean-marc-v)
Hello,
Same problem since 3.8.1
Regrads
Postato : 11/12/2019 10:59 am
BillC
(@billc)
@jean-marc-v
Should not be using 3.8.1 on a MK2S.
Bill
Tagaytay City, Philippines
Postato : 15/12/2019 7:43 am
