X axis idler pulley replacement?
fl0PPsy
(@fl0ppsy)
Does anyone know where to get a replacement x axis idler pulley for the MK2S ?
Mine has started getting a rather load clicking sound so it seems the bearing needs to be replaced. I've been searching around but I havent found the right size replacement at this stage.
I do have some 623zz bearing around. Is there maybe a pulley that can be printed which is the right size that could use these bearings?
Napsal : 12/04/2018 5:45 am
