Why is the extruder pulley made of Brass ?
Página 1 / 3
Shree Kumar
(@shree-kumar)
My printer was working perfectly for a few prints. Then I had to face my next bugbear -- the extruder pulley would keep coming loose.
I tried to tighten the extruder pulley again. I figured I had worn out the threads - that's why it would keep slipping.. So, now I am stuck. Surely my fault.
I have another printer. The extruder pulley is made of steel on that one. The screw doesn't eat the extruder.
A big question I have for now : Is there a specific reason why the extruder pulley is made of Brass ? (I am not blaming anyone for the choice of material, just wondering if there is any specific reason for this)
To fix the problem, I am considering getting another screw hole made on the same pulley. Is this the right way to go ? If there are other solutions, please let me know.
EDIT: I was actually able to fit another screw in the brass pulley - so maybe it is not completely worn out. Looks like I am unable to extrude. Tried cleaning the nozzle without much effect. Will look at the other things.
Respondido : 23/06/2016 6:18 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Why is the extruder pulley made of Brass ?
Hi Shree
Contact PR to get a replacement.
Don't know if you saw what happened to my drive gear:
Brass has some advantages over Stainless (cheaper, easier to make) but it does have some distinct disadvantages.
The problem I found was that SS replacements tended to be 1mm larger diameter than the Prusa brass one, so they cannot be simply swapped in.
I had to ask PR to send me a replacement (which they did FOC), even though I would happily have bought two or three had they been available in the shop.
So what happened to mine?, Well I do use filament which may have taken up some moisture and I guess the steam from that was pushed up the PTFE tube and corroded the outside of the gear. The the hole - that was simply where the brass was unsupported (on the flat of the motor spindle).
That said, I had used the Mk1 continuously for about 6 months and the gear had never come loose - the grub screw was very difficult to remove, so I do think your situation is not a common one, and is probably due to the supplied allen key.
Peter.
Respondido : 23/06/2016 9:45 am
Shree Kumar
(@shree-kumar)
Hi Peter,
I will do that. Let me hope the replacement doesn't cause any customs issues.
I saw the same thing today morning. I am thinking of getting the extra material removed. My local machinist with a small lathe can easily manage that I would imagine.
Whoa ! That is quite some thing to happen. Interesting picture, and thanks for sharing your experiences.
I think the allen key is surely to blame w.r.t these screws. It first caused me issues with the X axis and now with the extruder. Interestingly, the same allen key worked fine with the grub screw from the other extruder (from another printer).
Thanks!
-- Shree
Respondido : 23/06/2016 2:24 pm
PJR
 PJR
(@pjr)
Shree
There will be no issues with importing a replacement free of charge item. The commercial value of that item will be very small.
Getting an SS gear machined should be OK; the machinist must be experienced in turning stainless (it is nothing like working with brass!), but the problem I can forsee is achieving the "hobbed" drive with the correct angles so that the filament is not chewed up.
Peter
Respondido : 23/06/2016 3:58 pm
Shree Kumar
(@shree-kumar)
I think you are right on both counts. I hadn't accounted for cutting the hobbed drive.
Respondido : 23/06/2016 8:31 pm
gian mario.s
(@gian-mario-s)
I have the same problem with this pulley made of brass. I would like to fix it.
Is this Pulley sold here similiar and adatptable ?
http://e3d-online.com/Mechanical/Motion/GT2-Pulley-18-tooth
Respondido : 08/10/2016 9:05 pm
PJR
 PJR
(@pjr)
No, that's a belt pulley, not a filament drive gear.
Contact support via live chat.
Peter
Respondido : 08/10/2016 9:29 pm
David T.
(@david-t)
Try this: https://www.aliexpress.com/item/MK8-Extruder-Drive-Gear-Bore-5mm-For-1-75mm-and-3-0mm-Hobbed-Gear-For-Makerbot/32543429677.html
You need MK8 version.
You may need to adjust steps/mm for extruder.
Respondido : 08/10/2016 10:19 pm
Omikron
(@omikron)
I would also be interested in learning if there is a stainless alternative available anywhere. I take it the E3D hobb goblin is the wrong size?
Respondido : 08/10/2016 10:21 pm
PJR
 PJR
(@pjr)
David
I believe that the diameter is different to the PR brass drive gear. In order to maintain a straight filament feed path, the extruder housing will need to be redesigned and printed.
Peter
Respondido : 08/10/2016 10:33 pm
David T.
(@david-t)
We'll see soon 😉 I ordered 4 pcs two weeks ago.
BTW this http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=85008 fits perfectly, but it is made of brass as well.
Respondido : 08/10/2016 10:47 pm
PJR
 PJR
(@pjr)
David
I bought some a few months back... Fitted without mods and the filament won't load without a bend in the end. When loading the filament is pushed out of alignment by the offset.
Peter
EDIT: There are also issues when printing 50 micron layers due to less feed precision. At 50 microns, printing has to be faster than normal.
Respondido : 08/10/2016 11:11 pm
David T.
(@david-t)
Well, bad luck. 😆 I hope I will be able to use them in another printer.
Respondido : 08/10/2016 11:16 pm
PJR
 PJR
(@pjr)
Yeah, the problem is that the spindle is 5mm and the drive is only 6mm diameter; that means the brass is only 0.5mm thick (at the centre of the drive.
My first one collapsed at the spindle flat. The steel Mk8 drive pulleys have a drive diameter of 7mm and the extra half millimetre make a huge difference.
Peter
Respondido : 08/10/2016 11:21 pm
gian mario.s
(@gian-mario-s)
So this one does not fit ?
http://e3d-online.com/Extruders/Hobb-Goblin-5mm
There is no valid alternitive somewhere ?
Respondido : 09/10/2016 1:05 pm
PJR
 PJR
(@pjr)
That one is also a Mk8 and would have a 7mm drive diameter.
You can of course try that and see if it works.
Peter
Respondido : 09/10/2016 8:15 pm
simon.p
(@simon-p)
Anyone found a fitting pulley replacement yet? I am getting some filament skipping and would like to have one spare.
Respondido : 12/11/2016 6:28 pm
simon.p
(@simon-p)
Will this one work?
http://www.ebay.at/itm/3D-Printer-Filament-Extruder-Hobbed-Pulley-Drive-5mm-Bore-1-75-3-00mm-RepRap-/321455312149?hash=item4ad83acd15:g:SjwAAOSw91NTut0M
It has a hobbed diameter of 6mm.
Respondido : 15/11/2016 9:23 am
Thomas Gresch
(@thomas-gresch)
I'm having the same problem after printing some 30-40km of filament
I would be very happy to know from where to get more stable parts. Has anyone found a source for buying replacements?
Respondido : 19/11/2016 11:15 am
CptKirc
(@cptkirc)
Same problem here, got my Mk2 in September & today i saw that the extruder pulley has a hole on one side of the groove. Looks like the material is simply too thin oder not rigid enough. I hope i´ll get a free replacement for that.
Christian
Respondido : 08/12/2016 7:50 pm
Página 1 / 3
