thermistor repair
blorange
(@blorange)
thermistor repair
I'm getting "max temp" errors readings on my lcd as well as the temperature being noted around 460degrees once I turn on the printer.
Prior to this, my temp read wasn't accurate and you could hear the sizzling of the plastic as well as smoke.
I took a closer look and the sleeve on one side is frayed; part of it came off leaving one side of the thermistor showing as visible. (I think this is what Is there any way to repair?
Napsal : 18/02/2017 8:52 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: thermistor repair
The lower the resistance, the higher the temp reading. Looks like your wires are shorting somewhere.
The sleeve over the leads from the hot end is fibreglass; you can get replacement sleeving from E3D. http://e3d-online.com/Fibreglass-Sleeving?search=fibreglass
Peter
Napsal : 18/02/2017 10:16 am
