Supports not being added
I have enabled supports everywhere, but the area the arrow points to is not generating supports. It should have supports like the section in green.
I know it does a bridge, but that doesn't work well. I want supports instead.
How do I change that?
Thank you
RE: Supports not being added
Try, turning off 'Don't support Bridges'
In supports.
It's on, by Default.
Thank you very much! That option is confusing to me. The box was checked. To me that means if the box is checked that it won't support bridges.
I unchecked the box and now the support material is generating like I am wanting
Best
