Supports not being added
Tigra
(@tigra)
I have enabled supports everywhere, but the area the arrow points to is not generating supports.  It should have supports like the section in green.
I know it does a bridge, but that doesn't work well.  I want supports instead.
How do I change that?
Thank you
Napsal : 05/05/2021 5:34 pm
RE: Supports not being added
Try, turning off  'Don't support Bridges'
In supports.
It's on, by Default.
Napsal : 05/05/2021 6:21 pm
Tigra
(@tigra)
Thank you very much!  That option is confusing to me.  The box was checked.  To me that means if the box is checked that it won't support bridges.
I unchecked the box and now the support material is generating like I am wanting
Best
Napsal : 05/05/2021 6:34 pm
