Replacement bearings recommendation
Page 9 / 9
yang
 yang
(@yang)
RE: Replacement bearings recommendation
I have a Chinese bearing supplier whose bearings are very good. http://www.deep-grooveballbearing.com/
Posted : 31/12/2019 3:05 am
@omikron
I agree. Rather work with good quality than trouble with cheap goods. I only use SKF bearings on all my machines.
I am glad that there are still quality products to buy. You won't notice the difference until you try it.
Happy new year!
Posted : 31/12/2019 4:38 pm
cooldude
(@cooldude)
I am looking to replace bearings and rods on my new MK3s kit..Can i use LUMN-8?
Posted : 08/05/2020 6:28 pm
@amodak2014
I do not know the type "LUMN-8". Would you put a link to these linear bearings?
The correct dimensions to the bearings would be:
Outer diameter 15mm
Inside diameter 8mm
length 24mm
Posted : 08/05/2020 8:09 pm
cooldude
(@cooldude)
https://us.misumi-ec.com/vona2/detail/110300026540/?HissuCode=LMU-N8
Posted : 08/05/2020 8:13 pm
cooldude
(@cooldude)
I think these are same as LUM8 but without the seal
Posted : 08/05/2020 8:14 pm
Page 9 / 9
