Print fan issues
LensFlare
(@lensflare)
Print fan issues
I recently have been having issues with my MK2 failing the print fan portion of the self test. I have verified that the fan works by testing both the soldered points on the fan and the end of the connector to the fan with a 9v battery. I have also confirmed with the wiring diagrams that I have the fan plugged in correctly on the correct location on my RAMBO. Is my board fried at this point? Are there any other ways to test everything to see what might be wrong? I just want to see what I can do to confirm whats broken here before I order anything.
Thanks!
Opublikowany : 04/09/2021 7:54 pm
