MAXTEMP on MK2s
Marzouk
(@marzouk)
MAXTEMP on MK2s
Hi, I just assembled a new V6 E3D hotend on my MK2s, and as soon as I turned on the printer, the nozzle temp read was 732 but at the same time, it was cold. I tried a couple of spare thermistors that I had but it reads 287 while cold as well. I checked all connections on the board, removed all zip ties, and made sure the thermistor cable is not bent. I can't seem to find the problem here.. Any suggestions?
Postato : 20/10/2020 9:20 am
RE: MAXTEMP on MK2s
Posted by: @marzouk
Then I would check the thermistor with a multimeter. At room temperature. (about 25degrees C.) the internal resistance should be about 100kohms.
Postato : 20/10/2020 11:13 am
Clemens M.
(@clemens-m)
RE: MAXTEMP on MK2s
Not sure - but isn't polarity also important - have no possibility to check this at the moment,
Best regards, Clemens
Postato : 20/10/2020 7:21 pm
RE: MAXTEMP on MK2s
Polarity is not important when measuring the internal resistance, as well as the connection of the heating cartridge (resistance about 3.6 ohms), which in principle also represents a resistance.
Postato : 20/10/2020 8:31 pm
Marzouk
(@marzouk)
RE: MAXTEMP on MK2s
@karl-herbert
I measured the thermistor and it was about 120k ohm on 28c˚ room temp. Also when I take the thermistor from the board it gives me a reading of 20c˚. Is this a problem with the board? because I tried 2 extra new E3D thermistors that gave me the same reading. Even though, the printer was working fine before I replaced the hotend.
Postato : 25/10/2020 1:28 pm
