Live Z adjust not saving
MK2S, firmware 3.2.3.
Z value is not working correctly for some reason. It seems to be saved but prints start with no adjustment (0.00).
I have done factory reset twice, self test passes, xyz and z calibration passes, tested pinda with metal and cable movement does not affect it.
First layer calibration has been done and even V2calibration.gcode.
Done these with room temperature printer.
When I set the Z height I can print normally but after power cycle the height is wrong even though live adjust shows the number that I had set and I have to double it to get the print working.
Postato : 16/05/2025 10:21 am
Topic starter
answered:
RE: Live Z adjust not saving
Title might me misleading. Z value at least looks like it is saved but printer ignores it.
Postato : 16/05/2025 1:28 pm
