Layer shifting when using Prusa Slicer on I3 Mk2
Antowas
(@antowas)
Hello
Just seeing if anyone has his issue or a solution for it.  When I slice a file with Prusa Slicer and attempt to print it on my mk2, I always have a layer shift, sometimes multiple ones.  The same file sliced through Cura or S3D comes out fine.  See attached picture as an example.  Strangely, when I use Prusa Slicer for files on my Prusa mini they come out fine.  I don't recall changing any settings that would cause this.
Left print sliced with Prusa slicer, right print same file sliced with Cura
Publié : 07/05/2020 2:31 pm
Frausing
(@frausing)
RE: Layer shifting when using Prusa Slicer on I3 Mk2
This has also happend to me.
I was suggested to formatting my sd card, and remember to stop the card before taking it out of my pc.
I haven't had the problem since.
Publié : 15/05/2020 2:33 pm
Antowas
(@antowas)
I shall try that.  Thanks for the help!
Publié : 15/05/2020 7:46 pm
Frausing
(@frausing)
No problem 🙂
Publié : 16/05/2020 2:07 pm
