Layer shifting when using Prusa Slicer on I3 Mk2
Hello
Just seeing if anyone has his issue or a solution for it. When I slice a file with Prusa Slicer and attempt to print it on my mk2, I always have a layer shift, sometimes multiple ones. The same file sliced through Cura or S3D comes out fine. See attached picture as an example. Strangely, when I use Prusa Slicer for files on my Prusa mini they come out fine. I don't recall changing any settings that would cause this.
Left print sliced with Prusa slicer, right print same file sliced with Cura
Napsal : 07/05/2020 2:31 pm
RE: Layer shifting when using Prusa Slicer on I3 Mk2
This has also happend to me.
I was suggested to formatting my sd card, and remember to stop the card before taking it out of my pc.
I haven't had the problem since.
Napsal : 15/05/2020 2:33 pm
Topic starter
answered:
I shall try that. Thanks for the help!
Napsal : 15/05/2020 7:46 pm
No problem 🙂
Napsal : 16/05/2020 2:07 pm
