Layer shift at around 80-90mm
Rob Nance
(@rob-nance)
I first thought I had a slipping belt or something, because I paused some prints, and resumed. I'd come back later and find a layer shift. I believe the issue of a layer shift happening if I pause and resume still remains, but I realized the real problem is happening at the same height each time. I've moved things a ton, and can't find any possible place there could be a bind or catch point.
Any ideas on what it might be?
Postato : 30/08/2018 6:15 pm
lou.p
(@lou-p)
Re: Layer shift at around 80-90mm
Hey TexRob,
I started to have the same issue, but not at the same height and Now I can't get through a single print without having this same shift. I'll get a number of small shift, then I'll get a major one like you did, have you solved the problem yet. It's always in the same direction, I've checked belts, etc., but still no better?
Postato : 30/10/2018 1:28 pm
Camperinho
(@camperinho)
Mine, MK3 is doing layer shifts as well and I double checked my belts too, everything is fine, but still layer shifts. Hopefully anyone has a solution for this! =(
Postato : 05/11/2018 9:34 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Are you printing with Z-lift?
If not, do so (0.5mm should suffice). Also you could try slowing down the print.
Peter
Postato : 06/11/2018 2:30 pm
Camperinho
(@camperinho)
Yes, but I tried slowing down the print and double checked all pulleys and belts again - this seems to help so far. Hopefully it will stay this way 🙂
Postato : 07/11/2018 8:28 pm
