Latest Firmware for mk2
Eleusis
(@eleusis)
I recently resurected a mk2 and I upgraded firmware to 3.2.3. which seems to be latest on prusa website. Yet when I print something it gives me a warning to upgrade to latest firmware 3.9.3. This is confusing. Can someone advise?
thanks
G
Opublikowany : 28/03/2023 12:36 pm
victormccormicke
(@victormccormicke)
It's possible that there is a mismatch between the firmware version installed on your MK2 and the version supported by the slicing software you are using. The slicing software might be expecting a different version of the firmware, causing the warning message to appear.
Opublikowany : 28/07/2023 11:38 am
Hi G,
firmware 3.9.3 is intended for Mk3, Mk3S, mk3S+, mk2.5 and mk2.5S printers and was released in 2021 it is not appropriate for a standard Mk2 printer
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/3-9-3-firmware-for-mk3-mk3s-mk3s-mk2-5-and-mk2-5s-3/
the latest firmware for a Mk2 and Mk2 with MMU1, printer is 3.2.3
it looks like you may have an old version of Prusa Slicer and may have chosen the wrong printer profile.
do you have the latest slicer version?
the latest driver package can be downloaded from this site
https://help.prusa3d.com/downloads, this should include Prusa Slicer 2.6.0
Or if you prefer to download the slicer directly, this link may help
https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.6.0
Regards Joan
Opublikowany : 28/07/2023 12:17 pm
1 ludzie polubili
nrvrith
(@nrvrith)
Greetings from Crete guys!
I am facing the bed preheat error, each time I am trying to print. Wire connections are checked and working on top. The bed was then replaced, but problem was not solved even after the replacement. What do you syggest me to do?
Thank you!!
Opublikowany : 05/10/2023 4:39 pm
Meinofenbrennt
(@meinofenbrennt)
RE: Latest Firmware for mk2 - german or english?
Hello!
Pls help...
Is 3.2.3 only in cz ?
Which Version is last in en or german?
i thought i have to update and no my printer dont work...aiaiiaaiai
Br
Arnold
Opublikowany : 01/11/2023 9:23 pm
Meinofenbrennt
(@meinofenbrennt)
ahhh i found the menu with google translate 🙂
Opublikowany : 01/11/2023 9:30 pm
