I want to upgrade to a removable print surface
bp3d
 bp3d
(@bp3d)
Hi all,
I have a Mk2s I picked up from a local public school. It does not have a removable bed and that can be a real pain sometimes. I was thinking of purchasing this kit on ebay...
https://www.ebay.com/itm/266233635146?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bbPPJTUKRYe&sssrc=2047675&ssuid=gWVPH2QuRlS&widget_ver=artemis&media=COPY
My question is do I need a different PINDA than what is already on the printer for this upgrade? If so, do I also need new firmware? If so, what specifically do I need? Any help answering those questions would be greatly appreciated! Thank you!
Opublikowany : 10/07/2023 1:16 pm
The advert says there is a new PINDA included...
Opublikowany : 10/07/2023 4:31 pm
Hello
(@hello)
RE: I want to upgrade to a removable print surface
Buy a proper upgrade kit of Alixpress there really cheap and flash the firmware for that upgrade kit
Opublikowany : 10/07/2023 8:18 pm
bp3d
 bp3d
(@bp3d)
Link?
Opublikowany : 10/07/2023 8:21 pm
bp3d
 bp3d
(@bp3d)
I know. My question was do I need a new PINDA.
Hello
(@hello)
Yes you will don't have a link but on alixpress search mk2s to mk3
Opublikowany : 10/07/2023 10:11 pm
Hello
(@hello)
Or mk2s to mk2.5
Everything you need to know should be here:-
https://help.prusa3d.com/wp-content/uploads/2021/05/Original-Prusa-i3-MK2-to-MK2S-upgrade-1.pdf
https://help.prusa3d.com/guide/1-introduction_58840
TWO stages.
Opublikowany : 10/07/2023 11:24 pm
bp3d
 bp3d
(@bp3d)
Nvm, looks far to time consuming. Ill just buy a new one.
Opublikowany : 10/07/2023 11:50 pm
Hello
(@hello)
here you go you could get this https://www.aliexpress.com/item/32966916839.html?spm=a2g0o.productlist.main.1.466941e8HRjWcm&algo_pvid=723edae6-6b55-4c9c-8ebe-c3f23f3bf405&algo_exp_id=723edae6-6b55-4c9c-8ebe-c3f23f3bf405-0&pdp_npi=3%40dis%21NZD%21219.61%21208.63%21%21%21133.52%21%21%40211bea6216890423490573632d0791%2110000015499755099%21sea%21NZ%210&curPageLogUid=jeiuFCsemsQW
Opublikowany : 11/07/2023 2:27 am
Hello
(@hello)
or https://www.aliexpress.com/item/4000980273136.html?spm=a2g0o.productlist.main.11.466941e8HRjWcm&algo_pvid=723edae6-6b55-4c9c-8ebe-c3f23f3bf405&algo_exp_id=723edae6-6b55-4c9c-8ebe-c3f23f3bf405-5&pdp_npi=3%40dis%21NZD%21167.16%21167.16%21%21%21101.63%21%21%40211bea6216890423490573632d0791%2110000013148631578%21sea%21NZ%210&curPageLogUid=u7IXIhOaoGlK
