Heat Creep? Possibly another issue?
Brent
(@brent-3)
After experiencing a few issues I replaced a melted extruder cover and assembled hot end on my MK2S. After a few test prints with PLA I had a PETG print jam about halfway through. I took apart the extruder and found it jammed/caught after the ptfe tube. I replaced the PTFE tube and reassembled everything. Test print on PLA worked fine but jammed again during a PETG print. Honestly I am thinking I got a dud hotend as I havn't changed any settings.
Any ideas?
Publié : 01/09/2020 11:27 pm
Matt
 Matt
(@matt-19)
RE: Heat Creep? Possibly another issue?
Check to see if retraction is on, try printing it without; it will be a little stringy; I had a problem that sometimes it would plug itself; if that helps I can go into more detail about getting retraction back.
Publié : 02/09/2020 12:10 am
Brent
(@brent-3)
I will try but I have to get the filament unstuck again. Is tearing apart the extruder the best way to get it out? I will try this asap, thanks!
Publié : 02/09/2020 12:14 am
Matt
 Matt
(@matt-19)
For getting the filament out you can try undoing the spring loaded side, heat up the hot end to the hotter side of things and see whether a needle nose will help pull it out. There's a few things that can be done without having to touch the extruder for getting around the issue(I had melted a glob of ABS effectively destroying my carriage before and then I had this issue on my new carriage, most notably with PETG); a lot can be done code wise if it appears to be a retraction problem:
  1. Turn off retraction, if you can live with the increased stringiness (this should be accessible under your slicing program, advanced or expert user I believe if you are using Slic3r).
  2. Fine tune retraction so that there doesn't seem to be any issues (this will probably be on a material/manufacturer basis)
  3. Fine tune retraction and increase temperature.
  4. and the method I've gone with is to replace the heatbreak (with a new fancy titanium one), depending you may still need to tune the retraction some, but this definitely got rid of my blocking issue.
Good Luck!
Ce message a été modifié il y a 6 years par Matt
Publié : 02/09/2020 4:02 am
