FLSUN Prusa i3 Z axis problem after installing Marlin
katrina.s
(@katrina-s)
hello, community
I've just got a new 3D printer, a FLSUN Prusa i3, and I have some really bad problem with it.
I use Repetier, Arduino, Marlin and an autoleveling sensor
Since I've installer Arduino and Marlin, my Z axis won't go down when I press the Z HOME or the MAIN HOME (for X, Y and Z).
If I press the Z HOME, the hight increass of 2mm and the MAIN HOME increass the hight of 7mm then both reset the hight to 0.
If I increass the hight, without pressing the Z HOME or MAIN HOME, I can lower it with the software.
If I press one of the HOME I must lower it manually because REPETIER don't allow you to go bellow 0.
Before installing Arduino & Marlin I had no problem except for my LCD screen that I wasn't able to go in and it still not working...
If I was pressing the MAIN HOME, every axis was going at HOME, the Z axis was lowering, touched the plate then going 2mm higher and the extruder was going in the midle of the plate.
The firmware I had on my sdcard can be found here: https://github.com/vovcacik/Marlin
PLEASE can you help me?
Tutuapp APK9Apps APKAptoide Free Download
Publié : 28/06/2018 5:18 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: FLSUN Prusa i3 Z axis problem after installing Marlin
This is the support forum for printers manufactured by Prusa Research.
You should contact the manufacturer or supplier of your printer to assist with your problem.
Peter
Publié : 13/07/2018 11:47 am
