Flat spots on disc edges
Mark
 Mark
(@mark-21)
Hello, I'm new to 3d printing and this forum. I use my brother's Prusa mk2s printer. My "tube" print out has multiple flats with heavy angled joints. I saw a link for Solidworks but I'm using Seimans Solidedge Student Version.
How can I fix this?
I appreciate the help! Mark S.
Posted : 31/01/2023 4:03 am
All curves are approximated as triangles in the mesh file.  Your software probably has a 'quality' setting or similar, you might be able to set the number of facets in a circle - eg, 4 facets is a square, if you set 100 or more your flats should merge into a curve.
Posted : 31/01/2023 9:54 am
