Fix for X Belt twist?
JonB
 JonB
(@jonb)
Is there a fix for the x axis belt 'twist' issue yet? I added a toothed dual bearing idler which has helped reduce the bits of belt being shredded off. However, I still have the wobble in the belt. I saw a github post that this is due to the the holes in the x end that are not aligned (off 1 degree).
So, is there a new x-end-idler STL that has the fix? I dug through the printable parts but don't see any version control imprints that would lead me to believe a new x end has been published.
Publié : 13/08/2018 8:45 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Fix for X Belt twist?
Which printer is this for?
The post needs to be moved to the correct forum (this is the MMUV2 forum).
Peter
Publié : 13/08/2018 9:30 pm
JonB
 JonB
(@jonb)
Yeah - sorry. Came back to say this needs to move to the Mk2s or even MK2.5 forum.
Publié : 13/08/2018 9:58 pm
PJR
 PJR
(@pjr)
OK, given the options, I will move to Mk2 forum. Note this was posted originally in the Mk2.5/Mk3 + MMU V2 forum.
Peter
Publié : 13/08/2018 11:26 pm
stefan.l14
(@stefan-l14)
Hello,
I do have the same issue and it would be great if someone has some information.
Thank you
Publié : 25/10/2018 1:30 pm
coopster
(@coopster)
fist of all make sure the belt is installed correctly don't do what I did lol
https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f78/x-axis-belt-rubbing-t19119.html#p103157
next you can print a mod that tightens the x belt... (ironically you end up mounting backwards) that has help solve my problem
you can find several on thingiverse I used this one :
https://www.thingiverse.com/thing:2740715
simple yet effective
Publié : 06/11/2018 10:11 pm
