Extruder/Bed temp in Slic3r 2/S
kyle.d16
(@kyle-d16)
Have a newbee question. Trying to print a third party file https://www.thingiverse.com/thing:3308710 and I am having a heat problem. After importing the file I set the bed size then the extruder and bed temp to 210/55. Drop it flat. Then I convert to G-code but when I start printing the extruder does not heat, the bed does. What am I missing? 😕
Postato : 20/01/2019 5:05 pm
thedavinator37
(@thedavinator37)
Re: Extruder/Bed temp in Slic3r 2/S
This is a very obvious problem, but make sure that your hotend and all of its wires are plugged in.
Postato : 22/01/2019 1:17 am
kyle.d16
(@kyle-d16)
Got it working but it seems a bit too much so I must be missing something. For now I load the file in the PrusaControl to generate a config file I can load that in the Slic3r and the 3d file. Probably not as experienced yet with Slic3r so I'm sure I will figure it out.
Postato : 23/01/2019 2:04 pm
