[Solved] Does not print after preheat
martinda
(@martinda)
I had a clogged nozzle that I cleared, and I cleaned the hobbed pulley, but now it won't print.
After preheat I select the model to print.  It stabilizes the temperatures.  The printer then does the bed level check and goes to the front left corner and sits there.  The printing progress indicator (SD ###%) goes from 0-100 and then it says the print is done, but nothing printed and the head never moves.  It doesn't even print that little line at the front edge before printing the model, and yes, it was printing this same model file before the clog.
Does anyone have any idea what the problem is or how to fix it?!?
Thanks Much!
Dave
Napsal : 28/07/2020 7:19 am
