Display fail after firmware flash (I broke it! )
dizzy
(@dizzy)
This is what the LCD looks like after I did a firmware flash. The printer is a i3 MK2 but I suspekt it has been upgraded to a 2.5. The reason I think so is because the it asked me for a firmware update called 3.8.1 and that is not available for the MK2 and also when I tried to flash with firmware for MK2 it failed. BUT it also broke something. I flashed with the prusa3d_fw_3_8_1_MK25 and that worked lika a charm. But makes no difference to the issue with the LCD.
Things I tried:
Turn off and on
Turn off unplug wait 30 sek and plug in and turn on.
Flash again
Tried to make a "blind" factory reset but... well it is blind. Not working in other words.
Any one has anything on this? (not my printer...)
Respondido : 01/04/2020 4:07 pm
RE: Display fail after firmware flash (I broke it! )
Posted by: @alice
Things I tried:
Turn off and on
Flash again
Install the neweset PrusaSlicer (2.2.0) and try to flash this firmware after doing a factory reset: https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_2_3_MK2_MK2MMU.zip (FW 3.2.3 latest for the MK2). If this does not work i would contact the Prusachat.
Respondido : 01/04/2020 5:16 pm
dizzy
(@dizzy)
Posted by: @karl-herbert
Posted by: @alice
Things I tried:
Turn off and on
Flash again
Thanks for the tip! Problem is that the factory reset is impossible right now. =(
Respondido : 02/04/2020 5:08 am
Nswick
(@nswick)
Posted by: @dizzy
Things I tried:
Turn off and on
Flash again
Did you ever find a solution?  I am have the identical issue.
Respondido : 15/01/2021 7:23 pm
Instructions for factory reset can be found here: https://help.prusa3d.com/es/article/factory-reset_5749/
Have you double checked all ribbon cables for correct and tight fit?
The LCD panel may also be defective. You can find a replacement at Prusa or here: LCD
But you have to check if this fits for your printer.
Respondido : 15/01/2021 8:12 pm
dizzy
(@dizzy)
I did finally after 3 tries with different firmware manage to get it right. What I did not know was that the printer was updated to a 2.5 from a 2 and this apparently affected what firmware to use.
Respondido : 16/01/2021 7:57 pm
