Cold Pull without Disabling autoload
hxkrdtq
(@hxkrdtq)
My i3 MK2 doesn't have a disable autoload option. How can I do a cold pull without disabling autoload?
I'm also getting streaky extrusion. Nothing seems to be clogged or jammed. But sometimes when I start a print, there is a clicking sound. I checked to see if the extruder gear/motor was clogged or misaligned and it seems fine. Any suggestions?
Veröffentlicht : 01/10/2020 8:52 pm
Mitglied
RE: Cold Pull without Disabling autoload
Disengage the tension on the Bondtech Gears.  It will work.
Veröffentlicht : 01/10/2020 10:12 pm
straswa@googlemail.com
(@straswagooglemail-com)
On my very new i3 MK3 S, i had today a similar problem. Using automatic filament loading, the filament was pulled in, suddenly there was a clicking and the filament stopped to move. Now, even after disengage the tension on the Bondtech Gears I cannot pull out the filament anymore. I heated up the nozzle again, but, without ruining the whole extruder, I cannot do anything more. Do you have an idea, what i can try more
Veröffentlicht : 09/11/2020 7:16 pm
