[Risolto] Cannot update firmware
Seth
 Seth
(@seth-4)
I am trying to fix a mk2s. When I went to update the firmware to 3.2.3 through prusaslicer I got "Flashing failed. please see the avrdude log below." The screen, which was previously working, now shows nothing but rectangles. There is no
The avrdude log output:
"avrdude-slic3r -v -p atmega2560 -c wiring -P COM3 -b 115200 -D -U flash:w:0:C:\Users\setha\Downloads\delete\prusa3d_fw_3_8_1_MK3\prusa3d_fw_MK3_3_8_1_2869.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Sep 16 2019 at 11:15:49
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude-slic3r: ser_open(): can't open device "\\.\COM3": Access is denied.
avrdude-slic3r: Could not open port: COM3
avrdude-slic3r done. Thank you."
Best Answer by Seth:
@jack-b2
I contacted the Prusa helpline, who were very helpful and figured it out. I accidentally flashed the wrong firmware the first time, which screwed everything up. To put the correct firmware on, they had me download "Xloader" and in the options use device "Mega(ATMEGA2560)" to flash the correct firmware.
Beware though: I may be forgetting a step in their directions here, and I do not know the risks involved in this method. I would suggest contacting Prusa for proper directions.
Good luck!
Postato : 24/12/2019 8:32 pm
JackB
(@jackb)
RE: Cannot update firmware
I am having a similar problem.  I've tried to factory reset and I don't get a menu.  I don't see the text "Original Prusa i3 Prusa Research" on the display.
Postato : 29/12/2019 7:32 am
Seth
 Seth
(@seth-4)
@jack-b2
Good luck!
Postato : 29/12/2019 5:21 pm
