Calibration issues
Doug
 Doug
(@doug)
Calibration issues
I have a MK2S thats been working great.  decided to replace the heat sink and took the extruder apart all replaced no issues with heating.  Heres what does work:
Self Test:  Passes
Z Calibration works fine.
I've checked my Pinda Probe and it lights up and does acknowledge a metal object underneath it.  The Pinda probe is now lowered to almost the same level as my nozzle, not sure I could lower it anymore.
i'm updated to current firmware
problem comes when I try to do XYZ Calibration it gives me an error and says "Bed calibration point not found"  and the extruder nozzle is about 1/4" from the bed.
Any thoughts?  I've been google searching and nothing really helpful.
Veröffentlicht : 26/03/2021 3:22 am
RE: Calibration issues
Have you done a factory reset since the rebuild?
Veröffentlicht : 26/03/2021 10:33 am
Doug
 Doug
(@doug)
Just did factory reset.  Auto home worked.  The xyz calibration stops about 1/4 inch from the bed and after about 2 back and forth ot stops and gives the same error.
FYI.  The self test passes.  The z calibration passes, the mesh bed leveling passes.  Its just the xyz calibration that fails on step 1 of 4.
Ughhhhh.  Frustrated,  everything was fine until I replaced parts of the extruder.
Veröffentlicht : 27/03/2021 1:27 am
@doug
OK, this is out of my area; I suggest you contact Prusa support.
Log into your shop account, navigate to support and raise a chat session; that's bottom right in most browsers.
Veröffentlicht : 27/03/2021 12:25 pm
Doug
 Doug
(@doug)
Contacted support and all worked.  Now it's a different problem.
During xyz calibration  it locates point 1 amd goes back and forth to fine tune it.
Then it barely goes over point 2 and immediately moves to point 3.
I know the pinda works, I can move the extruder around the bed and the light goes out at all 9 points.
I'm at a loss as to why it skips point 2!  It continues with the calibration and keeps doing more iterations
Veröffentlicht : 28/03/2021 4:49 pm
It may be finding point 2 exactly where it expects it...
Does the calibration complete OK?
Can you get a good Z level and make a trial print?
Veröffentlicht : 28/03/2021 6:54 pm
