Broken extruder cables - Need a replacement
jendeeaz
(@jendeeaz)
Hi. I am a 6th grade teacher, and I just got my first Prusa Printer for my class though a grant... Unfortunately, while a student was helping to put it together, he accidentally broke the extruder cables. I have an MK2S. How can I get a replacement part?
Thank you for your help!
Jennifer
Publié : 28/05/2019 10:58 pm
RE: Broken extruder cables - Need a replacement
Contact Prusa (this is a user site - Prusa isn't listening here).
Log into the store, on the order page there is a CHAT window in the lower right: open it up and explain the issue to the on-line tech.  Prusa may or may not replace the broken part, but that's what I'd try first.  At the least, they can explain what you'll need to order.
Publié : 29/05/2019 7:48 pm
where are you located Jennifer?
for a mk2S you would require a replacement 12 volt 40 watt heater
Attachment removed
Publié : 29/05/2019 8:06 pm
