24 AWG stepper wire replacement
toby.k
(@toby-k)
I’m having intermittent issues with one or more wires to the extruder stepper motor, seems like I damaged them somewhere along the way and need to replace them. Since these are labeled 24 AWG and since I have lots of 24 AWG stranded Ethernet cable, can anyone think of a reason not to use it as a replacement other than the colors might not be OEM.
Thanks!
Napsal : 07/04/2018 6:30 pm
Re: 24 AWG stepper wire replacement
cat5 cable typically has 1 or 7 filaments of copper, neither of which are good for 3d printers
flexible 24 awg cable typically has 45 filaments, making it much more flexible
Napsal : 07/04/2018 8:52 pm
toby.k
(@toby-k)
Thx Joan, I'll dig into the wallet and buy the right stuff and wait for it!
Napsal : 07/04/2018 9:30 pm
I am having a weekend away from my printer,
if the new Pinda dsoen't arrive next week, I'll patch out the existing cable with whatever is to hand, to get me going for a couple of days...
But I am also going to order some flexible wire to have on hand, because it is only a matter of time, before things start failing, I have already had to replace the heat bed cables on both my Mk2 and Mk3... and the Pinda on My Mk2... I have a spare Mk2 one, but it won't fit the Mk3...
I also ordered a load of spares so I can do my own diagnostics... been in electronics and electromechanical equipment for a long time... unfortunately that means zilch if you don't have a video camera.
Napsal : 07/04/2018 11:25 pm
