use flexiplate on mk2s
rw
 rw
(@rw)
Can i use a builttak flexiplate on my 2s. I just want to buy the seperate plate withouth the magnetic bed and hold it with clips. Will my auto leveling then still work?
Opublikowany : 26/04/2018 10:39 pm
Re: use flexiplate on mk2s
if the flex plate has a steel core and the coating is not too thick then it should still work, but your Live Z will almost certainly need re establishing
probably best doing a Z axis calibration and live Z before trying to print on the new sheet. make sure the clamps you use, don't interfere with the frame or extruder assembly.
be careful setting it up.
regards Joan.
Opublikowany : 26/04/2018 10:47 pm
rw
 rw
(@rw)
I was going to order just the spring steel sheet. And ad a prusa pei sheet to it.
Opublikowany : 27/04/2018 9:36 am
JASII
(@jasii)
I am not sure if this applies to what you are trying to set up but as a reference I tried to see if the Prusa steel sheet from my MK3 would work on my MK2s. It did not. The PINDA could not register the alignment points under the beds. Too thick I imagine. But again, that is the PRUSA steel sheet w/laminate on both sides. Hope this helps.
- MK3s w/Mosquito Hotend- Mini w/Copperhead Hotend- XL - 5 tool -OpenScad -3d Builder -FreeCAD -Alibre -OctoPrint/x3(Pi3B)
Opublikowany : 27/04/2018 7:53 pm
Mk2 XYZ calibration would need to be done without the steel sheet.
Z calibration would be done WITH the sheet
Opublikowany : 27/04/2018 8:14 pm
Joe Prints
(@joe-prints)
**This was my experience... yours may vary**
I once had the BuildTak flexplate system on my MK2S..... It seemed that the magnets are so strong, and in the same area of where the PINDA senses the mesh leveling before the print... that it threw off my PINDA quite a bit. Adjusting the Z height initially was no issue- I actually lowered the PINDA a touch.
But after a few prints it was acting quirky- and I was constantly having to use the live Z to get a decent first layer.
After removing the system and flashing the Firmware it prints just like it did before.
Anything can be made better
https://www.myminifactory.com/users/Joe%20Prints
Opublikowany : 29/04/2018 4:08 pm
rw
 rw
(@rw)
I was just going to use the flexplate without the magnetic base. And use clips to plaxe the flexiplate.
Opublikowany : 02/05/2018 7:27 am
Joe Prints
(@joe-prints)
The problem with that is when the bed heats up, the center of the plate warps up( I tried that very same thing)
I suppose if you were just printing PLA it might not warp as hard as... say....PETG.. since the bed temp is lower
Opublikowany : 02/05/2018 1:19 pm
rw
 rw
(@rw)
Ok thanks for the feedback. Then that isn't an option.
Opublikowany : 02/05/2018 3:52 pm
