PID-Tuning
Christos
(@christos)
PID-Tuning
Im planing to do PID tuning, what temperature im going to tune, the one of the first layer (230) for PETG of (240) other layers?
Opublikowany : 18/05/2018 2:21 pm
GertL
(@gertl)
Re: PID-Tuning
I did for the remaining layers, so in your case 240.
Works fine for me.
Gert
Opublikowany : 18/05/2018 2:46 pm
JuanCholo
(@juancholo)
Re: PID-Tuning
i usually use 240 as i go back and forth between different materials and it is in the center for temperatures.
“One does not simply use a picture as signature on Prusa forums”
Opublikowany : 18/05/2018 5:00 pm
GertL
(@gertl)
Re: PID-Tuning
You can do PID tuning for every material you use and put it your GCODE start script.
Unfortunately I'm not in front of my PC so i can not show you how to do that.
I bet someone else will fill in here
Gert
Opublikowany : 18/05/2018 7:08 pm
Nikolai
(@nikolai)
Re: PID-Tuning
M301 command is doing the trick. As long as you don't write it to EEPROM with M500, it's only valid for the session.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 18/05/2018 10:47 pm
