First Layer Issue
Pierre-Jean Ferbos
(@pierre-jean-ferbos)
First Layer Issue
Hey guys !
I spent the past weeks reading and applying recommandationa on z axis calibration and first layer stickiness.
I have good results but ONLY when i reduce speed at least for first layer. I can’t get any sample even from the SD card at 100 speed.
The layers never stick.
I was wondering if this is normal and i shouls keep going or if this not normal and should co tinue to tweak my printer.
Thanks !
Peter
Opublikowany : 12/08/2018 2:05 am
BillC
(@billc)
Re: First Layer Issue
Are you running a MK2S? Some beds need a wipe with dishwashing soapy water when they are new. Just a damp paper towel and a good wipe down, then rinse off and dry with fresh paper towels before applying the IPA .
If you are still having problems after doing that, then a photo of your first layer going down and your live-Z value will be helpful.
Bill
Tagaytay City, Philippines
Opublikowany : 12/08/2018 4:26 am
Pierre-Jean Ferbos
Thanks , i will apply the follow and send you some pictures after testing.
Would you like me to use a specific model ? The calibration z is working. I can run the prusa logo at 100 and 30 speed for example and shownthe difference.
Would that work ?
Opublikowany : 12/08/2018 7:58 pm
BillC
(@billc)
Would that work ?
Perfect
Bill
Opublikowany : 13/08/2018 8:05 pm
