XYZ Bed Calibration Failure
cecile.c
(@cecile-c)
Hi, so when I calibrate my bed using the XYZ feature, the first four points are found successfully. Now, after the fourth point is found, the printer freezes for a split second, then the print head moves up slightly.
After it moves up slightly I get an error that the calibration has failed with no additional information.
Thanks for any help!
Publié : 25/12/2016 5:17 pm
ZARIBO
(@zaribo)
Re: XYZ Bed Calibration Failure
I recently solved missing front left calibration point error by re-aligning the nuts which are combining the Z frame and the Y axis. Z frame should be exact 10cm away from the rods at the back. (you should measure between orange parts and the Z frame)
Publié : 25/12/2016 9:22 pm
cecile.c
(@cecile-c)
Thank you! your solution worked!
Publié : 26/12/2016 3:49 am
