XYZ Calibration fails on the 4th point
Yukaputz
(@yukaputz)
I tried the xyz calibration and it failed on the fourth point. I verified that the nozzle was not touching the print bed, but lowered the pinda probe and reran it, it failed again on the 4th calibration point. I have a video posted here. Can someone tell me what to try next? I'm at a loss on how to fix this.
Respondido : 12/01/2017 9:17 pm
Yukaputz
(@yukaputz)
Re: XYZ Calibration fails on the 4th point
So i was searching the forum and verified my bed was level at all 4 corners by checking the distance from the bed to the table with a micrometer, loosened the power supply bolts to the frame, cleaned the bed, but still, it dies on the same 4th calibration point every time. I did verify the pinda sensor is less than 1mm higher than the nozzle. Also i watch the pinda blink on all the calibration points. I also tightened the loop on the pinda just a little. Help?
Respondido : 13/01/2017 12:30 am
Yukaputz
(@yukaputz)
So reflashing my firmware got me past the 4th calibration point problem. Then as it was going through leveling the nozzle crashed into bed. Lowered pinda, trying again. sigh.
Respondido : 13/01/2017 2:00 am
Yukaputz
(@yukaputz)
And now its back to failing on the 4th calibration point. ARGH! Can anyone help me please? Should I be asking my questions elsewhere?
Respondido : 13/01/2017 2:47 am
bcheck555
(@bcheck555)
Are you able to measure the pinda to bed distance and compare to the first three? I believe there is a range that it will work with, outside that range and it will fail. Hopefully others will chime in for you.
Respondido : 13/01/2017 2:58 am
MrMik
(@mrmik)
Some background info might help.
Did you build a kit printer or buy pre-assembled?
Has it ever worked before?
With 4th calibration point, do you mean the one next to the "105" on the bed or the one opposite?
Respondido : 13/01/2017 3:09 am
sandesh.r
(@sandesh-r)
Hi I had similar problem on 4th calibration.
Watch my youtube video
I solve by making x-axis belt tighter. I needs to be really tight but avoid using excessing force.
Respondido : 13/01/2017 12:08 pm
aleksi.t
(@aleksi-t)
I'm pretty sure that your problem can be caused by many things. I also had a lot of problems with the whole calibration phase and also similar issue as you are describing. My problems were fixed by reassembling the y-axis so it was surely as square as I could possibly make it with the tools and skills I had. I also readjusted the motor belts, they were a bit too tight (I think the official assembly instructions advice is too tight).
Respondido : 13/01/2017 10:18 pm
Yukaputz
(@yukaputz)
Hey guys, circling back. I spent several hours with the guys over at http://slackin.codehemi.com/ and we figured out the following. We suspect its a faulty pinda. Essentially, I manually moved, then powered up and lowered the pinda to each calibration point on the pei sheet till the light turned off and then verified a sheet of paper could pass underneath the nozzle at each of the 9 points. Then reran xyz and it fails at the 4th point, run again and its at the 3rd point, run again then it makes it to the 9 calibration sequence and fails at the 5th point and so on and so on. Prusa support agreed and they are sending a new pinda probe. We shall see.
Respondido : 14/01/2017 5:09 am
