Strange XYZ calibration error
hans.c
(@hans-c)
Hello, everyone.
I recently upgraded my Original i3 to the Mk 2 version, reflashed the firmware to the latest version, and ran the self-test OK. Homing all 3 axes works fine, with the P.I.N.D.A. probe centered over the first mark.
So far, so good, but when I run the 'Calibrate XYZ' routine, the probe finds the first 4 points no problem, then all 9 points no problem, BUT doesn't return to the 'Home' position. Instead, the probe ends up about a centimetre to the left of the home circle and I get a 'Calibration compromised' error, saying the probe can't find the front left point. ❓
I've tried it twice now, and both times the same thing has happened. I'm stuck. Any help would be greatly appreciated.
Publié : 07/12/2016 4:33 pm
hans.c
(@hans-c)
Re: Strange XYZ calibration error
Correction: the XYZ calibration routine completes twice (which proves the axes are aligned & nothing is slipping), but on the third go-round it fails to find the starting point. The probe ends up at about X-10mm from where it should.
Publié : 07/12/2016 8:57 pm
mung-feng.w
(@mung-feng-w)
Same here.
Publié : 09/12/2016 10:15 am
MrMik
(@mrmik)
Same here.
Did you also upgrade your printer, or is it a new i3 MK2?
Publié : 09/12/2016 11:53 am
tom.a3
(@tom-a3)
I keep getting an X/Y/Z fail as well only with mine it says cannot reach the front calibration points. The thing is I can see the status of the PINDA changing state over all 9 points. I have checked everything I can think of as the printer was working perfectly one day and the next day the prints wouldnt stick to the bed so I decided to re run the calibration and got this error. I have even reflashed the firmware and tried calibrating but get the same results each time. Getting really fed up now, even the help chat couldnt offer any advice.
Publié : 10/12/2016 9:47 pm
MrMik
(@mrmik)
Has your PINDA probe rattled loose?
I applied some threadlock to it once it was working well.
Publié : 10/12/2016 11:13 pm
tom.a3
(@tom-a3)
The PINDA probe is nice and secure.
Publié : 10/12/2016 11:34 pm
tom.a3
(@tom-a3)
I finally got mine to complete the X/Y/Z calibration with the "all axis are perpendicular" result by stripping it down and rebuilding it.
Still dont know why it went from working perfectly to needing a rebuild but its working so I am happy.
Publié : 12/12/2016 1:00 pm
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
Many of the XYZ calibration issues are caused by slipping X or Y belt pulleys.
Publié : 12/12/2016 1:15 pm
