Stiffening the extruder cable 3mm - alternatives to 3mm nylon?
Phil
 Phil
(@phil)
The 3mm nylon filament used to stiffen my extruder cables finally broke. I have some old 3mm filaments lying around, but only in PLA, ABS and NGEN and these become too brittle over time and break.
I don't really want to order a spool of 3mm nylon just for the sake of using 50cm or so.
Has anyone come up with a good alternative? 💡
Thanks!
Phil
Respondido : 18/06/2018 9:16 am
Re: Stiffening the extruder cable 3mm - alternatives to 3mm nylon?
Get a sample of nylon off ebay or your local filament supplier
If you can make an adapter from metal
Use ptfe tube
Regards Joan
Respondido : 18/06/2018 9:45 am
me gusta
Phil
 Phil
(@phil)
@Joan: Many thanks for having taken the time to reply. Unfortunately, getting a $8 nylon sample delivered to Switzerland costs in excess of $40 and local shops only sell spools of the stuff (I had already checked). Using a PTFE tube is intriguing - I'll definitely give it some thought.
Respondido : 18/06/2018 11:28 am
