P.I.N.D.A sensor failure on 4th Z calibration 4th stop
Mr. Sauce
(@mr-sauce)
So I  have a an i3 MK2 and have done minimal printing on it. Initially it ran great then it was packed up for the summer when school was out and when restarting the printer, the PINDA sensor failed letting extruder touch the bed n multiple spots. I reset everything and checked the machine then began to recalibrate. During Z calibration the PINDA sensor did not trigger and the extruder nozzle pushed hard into the bed leaving a visible dent. Now it will not make it past that point in Z calibration. Is there any way to fix this or do you I need to buy new parts? I have tried a few different things but with no success. I am new to these and just looking for some ideas. I included a picture of the bed and a video of the problem.
Thanks Tony
    PINDA Error Video
Posted : 30/12/2021 12:44 am
Bob
 Bob
(@bob-2)
RE: P.I.N.D.A sensor failure on 4th Z calibration 4th stop
Hi Tony,
    Sorry for the long delay, I hadn't see this before.
    It's hard to tell from the photo, but if the burned spot is only in the PEI sheet you can remove and replace it, you can get the part here: https://www.prusa3d.com/product/pei-ultem-sheet/
    The instructions to replace it are here: https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk3s-mk3-mk2-5s-mk2-5_23920/
Cheers
-Bob
Posted : 07/02/2022 2:44 am
Bob
 Bob
(@bob-2)
I grabbed the wrong instruction set, it's mostly the same instructions, but this is for the MK2. https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk2-s_23528
Posted : 07/02/2022 3:06 am
