mesh bed leveling fail- y axis grind
Jason
(@jason)
had my printer up and running the past few months, but recently experiencing some weird issues, when ever the printer starts the mesh bed leveling before the printing starts. the y axis would run perfectly at the first three points but when it goes to the second row, the y axis grinds.
some background information: i am running IGUS RJ4JP-01-08 in my y axis and using a y axis bearing clips to secure them (been in use for two months)
had no issues with this set up until recently. my calibration for xyz are perpendicular .
here is a video of my issue:
i'm not sure where to start to fix this issue....
Opublikowany : 08/01/2017 3:57 pm
patrizio.b
(@patrizio-b)
Re: mesh bed leveling fail- y axis grind
Does it move freely by hand when the printer is off? Does it move freely when using the settings -> move Y option?
Did you check the Y motor connector cable? Some are badly crimped and will make false contact.
Opublikowany : 08/01/2017 6:13 pm
robert.d2
(@robert-d2)
Sounds like your bed is getting snagged on something causing the y-stepper to skip steps. This results in the pinda not being able to find the target in the bed. Look closely for a screw head or tie wrap that may be hitting the frame.
Opublikowany : 08/01/2017 6:27 pm
Jason
(@jason)
i can move freely by hand when the printer is off. and it move freely when u move it under the move y option.
i will check later on the y motor connector. im so puzzle on what causing this issue ❓
Opublikowany : 08/01/2017 6:28 pm
JeffJordan
(@jeffjordan)
Member Moderator
also check the cable harness from the printbed and the extruder carriage. they shouldn't interfere, regardless of the carriage position !
Opublikowany : 08/01/2017 6:37 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Check the Y belt pulley is not touching the motor body.
You may need to move the pulley to the left and the motor to the right (from the front).
Peter
Opublikowany : 08/01/2017 8:24 pm
simon.p
(@simon-p)
Sounds and looks to me like the y axis starts resonating and binds.
Opublikowany : 09/01/2017 11:37 pm
