Loctite process
jordan.c
(@jordan-c)
Loctite process
Nothing like holding your printer upside-down for 20 minutes while your loctite sets
Napsal : 21/01/2017 8:22 pm
Re: Loctite process
I have not noticed a need for loctite...
did something come loose
Joan
Napsal : 21/01/2017 11:45 pm
avi.s
(@avi-s)
Re: Loctite process
Wow, that's a lot of loctite. I thought you need only a drop. After all you do want to be able to remove it in the future if needed.
Napsal : 22/01/2017 9:13 am
David T.
(@david-t)
Re: Loctite process
In this case, it is much better to use a small drop of hot glue instead of loctite. It is much easier to apply and it is much easier to remove.
Napsal : 22/01/2017 12:21 pm
jordan.c
(@jordan-c)
Re: Loctite process
Yeah, it was too much, the stuff is like water and it isn't like I was in a comfortable position to be precise. I hope to never have to undo it. My Z adjustment is just -530 so I have some space.
Napsal : 22/01/2017 6:02 pm
jordan.c
(@jordan-c)
Re: Loctite process
Joan
You never want the pinda probe to move. Ever. Best case your prints fail for not sticking to the bed. Worse case, you damage your bed.
Napsal : 22/01/2017 6:04 pm
Carsten
(@carsten-2)
Re: Loctite process
I broke my Extruder housing while trying to remove my pinda for some maintenance. An i only used a small bit of loctite as i am used to from my rc Helis. That pinda holder is quite flimsy.
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Napsal : 22/01/2017 6:20 pm
Cristian
(@cristian-3)
Re: Loctite process
Me too!
Will not be using Loctite again on the PINDA probe...
Napsal : 20/02/2017 8:23 am
