LCD not working, i3 MK2S kit just assembled
kenneth.b9
(@kenneth-b9)
I just assembled my MK2S kit, turned it on, and the LCD displays a screen with four lines:
28/0 Z 0
28/0 100%
SD---% 0--:--
Prusa i3 MK2 ready.
If I _press_ the dial, I see a different screen
Info Screen
Preheat
No SD card
Load filament
Pressing the dial causes the display to switch back and forth between the two screens above. _Turning_ the dial causes the displays to change the displayed characters, resulting in gibberish.
I don't see any screens about firmware version, self-checks, or anything like that.
Any suggestions?
Opublikowany : 28/08/2018 3:06 am
justin.p16
(@justin-p16)
Re: LCD not working, i3 MK2S kit just assembled
Have you got this working?
I just assembled mine and I have the exact same issue.
EDIT: Video link below
Opublikowany : 10/09/2018 3:48 pm
justin.p16
(@justin-p16)
Kenneth, I just had some help from someone on the shop's livechat.
After trying out a few options we concluded for me it was probably a loose wire. Hopefully it is/was the same for you.
For anyone else in the future the advice I was given is consolidated below
  • If you've unplugged everything and plugged it back in again and it's still not working, unplug everything other than the PSU and the LCD.
  • If the error persists it is most likely a faulty LCD/cable.
  • If not, plug in each one of the other cables one at a time and check after each cable. FYI power off before plugging in more cables to be safe and then start back up.
  • You should be able to find out which cable is causing the error this way, or if you're lucky like me then the error will disappear
    Good luck.
    Opublikowany : 10/09/2018 5:54 pm
    edouard.g
    (@edouard-g)
    Hello everybody,
    I have exactly the same problem that is shown on the video of Justin p6
    I have checked all wires but the problem remains
    What can I do? thanks for help
    Opublikowany : 03/12/2018 5:11 pm
