Issues with "sharp" corners
Joe
 Joe
(@joe-15)
Hi everyone,
I wanted to print some parts of the MPCNC and after finishing the first part and inspecting it, i found something strange. The part exhibits some issues with one corner of the parts, please see the images. On the same layer, the corners are different, one crisp and the other "smeared" - for lack of a better word.
Any clues as what the reason might be?
Opublikowany : 01/12/2018 8:07 pm
RichHomieTee
(@richhomietee)
Re: Issues with "sharp" corners
I had the same problem happen to me. The way I fixed it was by re-calibrating the z-axis. If I may ask, did you re-calibrate the z-axis before or after you printed the part shown above?
Opublikowany : 12/01/2019 11:27 pm
have you tried turning that part say 45 degrees, see if the problem persists?
that looks like a cooling issue to me.
Opublikowany : 12/01/2019 11:43 pm
