Issue putting together x-axis
R0b0tn1k
(@r0b0tn1k)
Hi, I just completed the X axis according to instructions, however, the thing that moves never hits the X-stop.
Here's a video of the issue, and how I put together the axis.
Please advise..
Posted : 02/02/2017 11:13 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Issue putting together x-axis
your lower bearing sits not in place. seems that you haven't pushed it completely into the carriage holder, or something is blocking it.
you can see it pretty clear at your video (@ 40 sec). the bodies of both parts shoud be parallel.
❓ did you print the parts yourself ?
they don't look like the ones from prusa.
so be aware of the proper dimensions. looks like your abs print might have the wrong dimensions due to the shrinkage of abs while printing.
Posted : 03/02/2017 12:14 am
R0b0tn1k
(@r0b0tn1k)
I pushed the bearing all the way down now, however it still does not resolve the issue.
The parts are Prusa original, I got them from the kit.
Posted : 03/02/2017 12:26 pm
ryan.c4
(@ryan-c4)
You can ether take the bearing off and see what is holding it forward behind it, or slightly slant the endstop so it does trigger. This will cause problems later on however.
Posted : 04/02/2017 2:38 pm
R0b0tn1k
(@r0b0tn1k)
I was able to fix it. I cant really explain it, I just applied pressure from the opposite site, and it set it self up correctly. It's working now.
Posted : 04/02/2017 5:10 pm
