first print batman logo
marianne.b
(@marianne-b)
I just assembled the MK2 kit and after the v2 callibration, I decided to print the batman logo. But this doesn't come out the way I expected. It looks like it misses some lines at the righhand side on the front and also at the back.I started a second print and the second one looks better but still misses the lines at the front. And I am not so sure how the finished top should look. I used a silver coloured PLA and used the standard slicer settings.
I am, as many others, new to 3D printing and have some lack of knowledge where to look.
Any help will be welcome
Marty
Opublikowany : 03/01/2017 12:14 am
bpul
 bpul
(@bpul)
Re: first print batman logo
Print a test cube and lets see how that looks first.
From there hopefully we can get this narrowed down.
Opublikowany : 03/01/2017 1:07 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Print the pre-sliced Prusa Logo from the SD card.
If you don't have any issues then you will know it's the model/slicer settings.
Peter
Opublikowany : 03/01/2017 7:23 am
marianne.b
(@marianne-b)
thanks for the quick reply. I'm going to give both suggestions a try and will let you know the results as soon as possible.
Thanks again for respondent so fast
Marty
Opublikowany : 03/01/2017 2:32 pm
marianne.b
(@marianne-b)
as you suggested, I printed a cube 2x2x2 and the Prusa logo from the SD card. It's hard to make a decent photo but I will give it a try. The cube looks OK allthough I am not sure if this is what it should look like. I am aware that it is printed and lines are inevitable, but I'm not sure if it is supposed to look like this. Maybe you can give me a hint if this is ok or not. If the photo is telling enough 🙂
The Prusa logo shows some misty lines at the bottom left, which is actulally the right side, at the same place as on the batman. Also the corner is a bit warped. Again, I am not sure how this should look like.
Is this a bit helpfull to address the issue?
Opublikowany : 03/01/2017 10:34 pm
marianne.b
(@marianne-b)
I'm not seeing the Prusa photos, so another try
Opublikowany : 03/01/2017 10:35 pm
PJR
 PJR
(@pjr)
Looks as though your bed needs a good clean and lower Live Z Adjust by about 25 microns.
Peter
Opublikowany : 03/01/2017 10:37 pm
defsdoor
(@defsdoor)
I'd turn your part cooling fan down quite a bit also.
Opublikowany : 03/01/2017 10:52 pm
marianne.b
(@marianne-b)
thanks for the advise. I'm going to look into that tonight. Although I do clean the bed before every print with isopropanol tissues. But I will certainly look into the Z position and fan.
I will let you know what the results are.
Marty
Opublikowany : 04/01/2017 7:56 am
