Calibrating XYZ
calogero.b
(@calogero-b)
Calibrating XYZ
Has anyone noticed that while calibrating XYZ, when the hotend moves to the next position, the z axis moves down (closer to the hot bed), then across to the next position, instead of moving up and then moving across. This means that there is a real possibilty of the nozzel scratching the surface of the hot bed.
Hope that makes sense.
Opublikowany : 02/10/2016 7:26 pm
john.m7
(@john-m7)
Re: Calibrating XYZ
That may mean you probe is too high ...
Opublikowany : 03/10/2016 9:52 am
