[Closed] Filament not loading well in MMU1
TestKees
(@testkees)
Loading filament to my i3 MK2s MMU1 sometimes succeeds at once, but often it doesn't reach the end of the tube, some 5-10 cm too short. This can happen in all 4 extruders. If so I have to load a second time: not good for the gears I suggest. The tubes are tested allright.
So: what causes the problem? Is it the firmware - latest alive -, if so how can the loadinglength be changed. Or what is it?
Hope somebody can help...
Thnx in advance, Kees (from the Netherlands)
Napsal : 27/11/2019 7:35 pm
