Irregular first layer problem
Carl A
(@carl-a)
First layer .2 PLA Irregular printing First layer .2mm .4mm layer .8mm layer
I have changed speed, changed Z height, changed temp of both bed and extruder but keep getting same problem. Happens with both PLA and PETG. Do I have a heat bed problem? Or am I missing something?
Veröffentlicht : 19/01/2023 1:44 am
Your first layer 'Z' offset is calibrated a little too low.  It looks like there are fingerprints on the build sheet in a couple of places near the edges.
Veröffentlicht : 19/01/2023 5:50 am
Carl A
(@carl-a)
RE: Irregular first layer problem
I clean my bed with alcohol between each printing. I will try again to adjust my Z axis offset. Have messed with this before but did not solve problem. Will advise
Thanks for the answer.
Veröffentlicht : 20/01/2023 3:44 am
If that's not shifting it then it's time for the dishwashing detergent (Dawn/Fairy) and plenty of HOT water.
Veröffentlicht : 20/01/2023 10:45 pm
